Split Case Centrifugal Pump Suction Pressure Issue
I am running a 750 gpm Split Case Centrifugal Pump . It has positive pressure in suction side (Pump Inlet is connected at lower part of reservoir )
But whenever i start the pump , the pressure gauge at suction shows negative pressure . Is it normal ?
Also what will be the Net Pressure ? Discharge P + (-Suction P) or Discharge P - (-Suction P) ?
Thanks in advance .
RE: Split Case Centrifugal Pump Suction Pressure Issue
It is not unusual to have a negative gauge pressure at a pump's suction. You still should have positive absolute pressure on the suction side of the pump.
Absolute pressure is zero-referenced against a perfect vacuum, so it is equal to gauge pressure plus atmospheric pressure. Gauge pressure is zero-referenced against ambient air pressure, so it is equal to absolute pressure minus atmospheric pressure.
The pressure on the pump liquid level is atmospheric, so the pressure at the pump's suction will be atmospheric less elevation gain less hydraulic losses. Not a problem if the system is adequately designed to accomodate this.
To be sure the pump suction pressure is the absolute pressure of "psia", not in "psig". And, the NPSH of the suction piping system should be higher than the required NPSH of the pump as specified by the Manufacturer.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
