I am running a 750 gpm Split Case Centrifugal Pump . It has positive pressure in suction side (Pump Inlet is connected at lower part of reservoir )
But whenever i start the pump , the pressure gauge at suction shows negative pressure . Is it normal ?
Also what will be the Net Pressure ? Discharge P + (-Suction P) or Discharge P - (-Suction P) ?
Thanks in advance .
Thanks in advance .
