API 650 Appendix F - max design pressure
I am checking the allowable internal pressure for a tank designed to API 650. The plant wants to add a nitrogen blanket and the process engineer wants this information in order to design the pressure-vacuum relief valve. I was using the equation in F.4.1, which includes the tank diameter, but does not give units for this variable. If I use 'feet' I come up with a pressure greater than allowable for API 650 tank construction. If I use 'inches' I get a rather small value (around 1 in-H20) which seems too low. So, what are the units for this calculation?
RE: API 650 Appendix F - max design pressure
D is feet, P is in inches of water. Pressure will also be limited by F.4.2 if applicable. For a small tank, you may calculate a pressure higher than the 2.5 psi, but it's limited to the 2.5 psi to use API-650.
Don't forget to check the need for or adequacy of anchors when adding internal pressure, especially if the tank is not small in diameter...
JStephen, IFRs,
Thanks for the responses.
Another question, in F.4.2 when calculating the weight of shell and structural attachments (for evaluating WDL), do you include the floor plate as well? I assume the intent is the total weight of the tank, minus the roof and any roof structure.
Floor plate is not included.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
