G1 GRAVEL
G1 GRAVEL
RE: G1 GRAVEL
The base material appears to be a well graded mix; it would be a matter of plotting it and comparing it to a Fuller or Weymouth curve. The sub-base is less intense. An aggregate mix does not have to meet anything other than what is spec'd; whether it works is another issue. Many jurisdictions have a standard Granular 'A' or 'A' Base and these often have a similar gradation. Maybe someone on the forum can advise if there is a 'legal' or 'standard' Granular 'A'. I've only seen the gradation spec'd and have never compared the specs for it.
Dik
RE: G1 GRAVEL
Thanks Dik, but is there an official, technical standard showing aggregate/gravel gradation for G1 gravel?
RE: G1 GRAVEL
Try looking in the standard specifications of the department of transportation for the state or other jurisdiction where it would be used.
It could be like "Item 4" in parts of New York, a generic term for subbase gravel still in use, long after the relevant specification has been renamed. If that's the case, use the current spec. Since there is no spec for "Item 4," it could be pretty much anything that looks like subbase at first glance.
RE: G1 GRAVEL
Is it a local definition? It's just a matter of doing a sieve analysis to see that it conforms to the gradation... and a check of the constituent components for their conformance.
Dik
RE: G1 GRAVEL
AC - I have the spec for Item 4 if you need it.👍
RE: G1 GRAVEL
AC, can I take a look at it? Does the spec reference technical standards like ASTM or AASHTO?
RE: G1 GRAVEL
OP - The spec I have for Item 4 is about 60 years old. I can post a copy when I get home.
RE: G1 GRAVEL
Material Spec for Item 4 (1962)
RE: G1 GRAVEL
Thanks, B.B.!
My glass has a v/c ratio of 0.5
Maybe the tyranny of Murphy is the penalty for hubris. - http://xkcd.com/319/
RE: G1 GRAVEL
No problem AC. The book has helped me out a few times.
RE: G1 GRAVEL
bridgebuster:
Could you give us the book title, author & publisher and the copyright date, plus any other information you wish to share about it.
Thank for the post.
Jim
RE: G1 GRAVEL
Jim structures: NYS Department of Public Works Standard Specifications, 1962.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
