Tire Inflation Pressure for SPMT
Ariel Reyes
PH
I am currently working on the pavement design for a concrete road on which a self propelled modular transporter (SPMT) will pass. Need help on the tire inflation pressure for SPMT with a maximum payload of
500 metric tons. Thanks
Haven't the foggiest. Have you tried asking a manufacturer?
I will try asking or maybe from the SPMT manufacturer. Thanks
You need to ask the manufacturer, as each manufacturer decides what type of tire to us. This one says it uses solid tires, while others use standard truck tires.
TTFN (ta ta for now)
