NiMH Battery - Discharge profile - Honda Insight module
Hey everyone,
I'm currently working on the Honda Insight cylindrical modules 101V NiMH, trying to recondition and just experimenting with them.
Nominal cell voltage = 1.2V
I came across a discharge profile that I'm not at all familiar with. Running the module at 3.25 Amps to a target voltage of 6 volts (shut-off voltage). The thing that confuses me the most is for the battery with the black discharge line, I see a horizontal line for about 38 minutes, while the rest follow a conventional discharge curve. After the 38 minute mark it follows a conventional discharge curve.
Furthermore, each line corresponds to one battery being discharged (containing 6 cells each).
My question is - What is the theory behind this? And why did it lag? Does that mean in any particular way that this module is a bad/good one? What can we interpret from this?
Much appreciated, thank you!
RE: NiMH Battery - Discharge profile - Honda Insight module
Leaving everyone with the first question - where did you come across this graph?
While discharging used NiMH Honda batteries using a software plugged on. Further information: These batteries have been sitting around for a while, probably about 2 years.
So each of these is really a battery pack, many cells with some embedded electronics?
Have you recharged these and re-run the discharge curves?
I am guessing that the black one has some electronic control features that the others lack.
Did you re-run the test? It looks like the load just wasn't applied for most of the test. Since it died more quickly from the time the load looks like it was applied and looks like it rebounded to a higher voltage it would seem to have some other defect as well.
Are those curves all single batteries in one series pack?
Keith Cress
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
