Allowable Capacity of C1020 Cold-Rolled Steel
Can someone tell me what allowable capacities are used when determining the allowable capacity of C1020 Cold-Rolled Steel?
I know what the tensile strength and the ultimate strength mechanical property values are, but, is there a code book or some other reference that describes the safety factors that must be used when determining the allowable shear and allowable tension of this material?
I am not so sure the AISC 360 Steel Construction Manual formulas apply to this material when determining allowable capacities, do they?
Thanks for any help...
RE: Allowable Capacity of C1020 Cold-Rolled Steel
Are there any references available?
There will be certain specifications permitted, and these will then have minimum mechanical properties listed.
Then you to design codes for either permitted stresses or required safety factors.
forum507: Structural engineering other technical topics
Best regards - Al
