Stem Wall/Slab Detailing
Hi, I have a project where an elevated concrete slab for a new cmu electrical building is under construction. The slab is elevated a few feet above grade due to the flood level and is supported by a concrete stem wall with strip footings around the perimeter. Both the slab and the stem wall are 12" thick with double layers of reinforcement. Where the slab frames into the stem wall the horizontal rebar in the slab ends in 90-degree standard hooks and the vertical reinforcement in the stem wall also ends in 90-degree standard hooks. This is a detail I've seen typically however someone mentioned that the vertical reinforcement in the stem wall at the outside face should splice the top layer of reinforcement in the slab (negative reinforcement). Because I've never seen this I'm not sure if it's overkill. What do people typically do in this situation?
RE: Stem Wall/Slab Detailing
You always want to terminate your reinforcing on the far face/surface. Rebar is for tension, and, if you terminate reinforcing from the inside face to the nearest concrete surface over it, your 90deg corner can spall the concrete off.
Dik
I always splice the wall reinforcement into the slab to get continuity in the corner.
Quote (dik)
The rebar would be spliced on the opposite face. I've attached a pdf I threw together real quick to show what I'm talking about.
Quote (avscorreia)
I'm unsure of how that would help? I've always considered the joint between the slab/wall (shaded area in my sketch) as a fixed point so that as long as the rebar in the slab/wall is developed at the interface then I'm good. if the force is in the top mat is transferred to the spliced bar I don't see how it can 'turn the corner' into the stem wall rebar?
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
