Good day
This is my first post to the forum.
I'm working on a project where are taking smelter off-gas to a fermentation plant for ethanol production. The off-gas has some moisture and dust in it (we are looking at removing the moisture and dust in a knock-out pot, expect to have around 20 mg/Nm3, max size 30 micron dust and no droplets after knock-out), and the composition is slightly variable (±15% on molar mass). The available gas can fluctuate greatly (50%), so the turn-down on the compressors is important.
The compressed gas needs to be oil-free. I'm looking at oil-free screw compressors or centrifugal compressors. Any advice on the selection would be appreciated!
The process conditions are:
Suction pressure: 83 kPa(a) [12.038 psia]
Discharge pressure: 700 kPa(a) [101.526 psia]
Suction temperature: 35 degC
Nominal flow: 16000 Nm3/h [13.6 MMscfd]
Nominal molar mass: 24.3 g/mol
Thanks for your help!
