Reducible Live load
Reducible Live load
Reducible Live load
I have a question, if you apply Reducible Live Load in Etabs Model 2016, does the output of column Reaction Forces also Reduces?
RE: Reducible Live load
I'm assuming you're referring to 'joint reactions' or similar tables. The answer is no. Live load reduction is only performed when you run design checks. For columns, live load reduction would only shown up in the 'column design forces' table.
No it is not affected.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
