Simulating yielded state on an E-clip
I performing a stress analysis using solidworks simulation on a standard E clip and was wondering how I should interpret the results. Specifically, I'm trying to simulate what happens during insertion- when I apply a displacement boundary condition on the lead-in, I see multiple areas where the stress goes above the yield stress of the material but these could be characterized more as stress concentrations i.e. the stresses in the bulk of the material are still well under the yield stress.
So the question is - is there any way to simulate what happens to the part after yielding? I'm guessing in this case, that as the bulk of the material has not yielded, the clip will return to almost its original state and the effect of yielding will be minimal. Is this something that is commonly done or is the goal of any stress analysis always to keep all the max stress under the yield stress?
RE: Simulating yielded state on an E-clip
Wunderbear
It seems the stresses are stress concentrations around the inside rounded corners. If the amount of stress concentration is not large enough and limited to 1 layer of element in depth and 2 to 3 elements wide, you can straight away ignore it. But if the loading is in cycles, which I Guess is(Insertion and retraction of E clamp), you may need to find out fatigue life for given loading cycles. You cannot ignore peak stress or stress concentrations for the cyclic loading.
In real life the stresses at corner will yield the corner and redistribute themselves. The yield area will be very small and it can be safely assumed that the overall behavior of the component is elastic.
If you want to check how much area of the component yields, run elastic-perfect plastic analysis.
Please post your mesh.
What material properties are you using ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
White Paper - Comparing Multi-Patterning at 5nm: SADP, SAQP, and SALELE
Self-aligned multi-patterning techniques such as SADP, SAQP, and SALELE are increasingly popular at advanced nodes, but each process has its pros and cons. IMEC and Mentor, a Siemens business collaborated to identify potentially less-obvious process and design limitations and trade-offs between the three SAMP techniques. Learn more in this paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
