Vibration acceptance criteria for equipment tested at lower loads
cowpen
SG
I'm trying to gain some insight if there are any common practices for vibration acceptance criteria when an equipment is not tested up to it's rated load.
For context: we have a generator which is connected to a turbo expander; the power generated would be a function of the process conditions (dP, flow, density). At the moment, process conditions will only give us approx. one third of the power.
I work on the client side- but it is not clear to me what criteria may be used since we won't be operating at design conditions. (instrumentation available: proximitors, accelerometers)
There may be advice in some standards such as BS ISO 10816-2:2001?
