Vibration isolation in commercial truck
Hi All,
I am mounting a rectangular structure(115 lb)on the underbody of a commercial truck and need to isolate the vibrations being transferred from the truck while driving; The truck produces a low random vibration (1-15 Hz). I have been exploring options such as visco-elastic rubbers, and seeing if there's a product more "high-end" as far as actively correcting for any vertical displacement. Such as actuators. But I have not found a product off-the-shelf so far...
Any recommendations (companies, products.. ect) or guidance as to what would be best for isolating vibrations as much as possible? As expensive as the options might be!
The isolation could be either from below or above (hung).
RE: Vibration isolation in commercial truck
I'm a bit confused as to what you want to do. If you isolate the box from 1 Hz then the truck will climb the hill and your box will burrow into the road.
Which part of the frequency spectrum are you actually bothered by?
Cheers
Greg Locock
Thank you, Greg. The Bose system sounds like it could be a candidate although it looks like they sold their technology to ClearMotion and ClearMotion is still in R&D phase.
I'll put some accelerometer this week to get a realistic idea of what the vibrations range from a commercial truck. But yes, I need to minimize the vertical vibration as much as possible as I have sensors that are very sensitive to the vertical motion.
Thank you guys for the links, I am checking each one.
Perhaps you'd be better off measuring the acceleration in situ and compensating your other sensors.
As Walt implies, isolating for 1 Hz passively is not normally achievable (although it is possible) and not normally required. If you are serious about 1 Hz, perhaps you should be floating the item in a fish tank.
Cheers
Greg Locock
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
