Spur gears/bevel gear problem
Simen
1
Hi!
I'm working on a project where I've encountered a gear problem.
References on the picture in attachment:
n1 = 30 rpm
n2 = 2rpm
Rotary shaft on motor: diameter = 6,36 mm
Minimum D2 = 27 mm
I guess I need a 2 step transmission, but I find it very complicated to solve.
Anyone wants to help solve this problem?
(Motor can be repositioned)
 https://files.engineering.com/getfile.aspx?folder=de8be9db-cc1a-4667-bc55-eeb46401c64e&file=Eng-tips.PNG
