Passive Resistance of Berm
I'm trying to get a preliminary idea on sizes/anchors, etc, for some excavation bracing for an excavation to an existing bluff.
How would you estimate the passive resistance of the berm in front of the sheet piling. This seems to be somewhat debated.
I'd be interested in using both short duration values and long-term effective values (mixed phi-c)?
If I use some sort of effective slope, it exceeds the effective friction angle. The effective soil values are approx phi = 28-32 deg and c= 200-500psf.
Thanks!
EIT
www.HowToEngineer.com
RE: Passive Resistance of Berm
At a Qu at 4 - 5 t/sf, why not just cut back the upper slope to match the original? Assuming the former slope was stable. Driving sheet piles may cause some problems not anticipated.
The slope is suffering due to erosion and they'd like a vertical cut at this location. I believe it may be a permanent sheet piling.
EIT
If the existing bluff is fairly stable now, why not just flatten the slope back to the same spot that the top of the sheeting wall would be? First, analyze the existing slope using estimated soil properties to show a safety factor of 1 and then use the same properties to analyze the new, flatter slope.
Also, I would expect a 30' or wider flat area in front of the wall to provide full passive resistance. A tiedback wall would not be the first solution that I would investigate. Will you be able to even drive sheeting that deep into soil that stiff?
www.PeirceEngineering.com
Thanks for the additional comments and you have good points (as usual). A few responses:
Quote (PEinc)
I believe they want to create a level platform at the new bench elevation.
Quote (PEInc)
Good idea. I still need to give this some thought as far as going from a phi-c soil and applying that correctly to find a K.p for the sloped condition.
Quote (PEinc)
Meaning you would try using a cantilever?
Quote (PEinc)
That's a very good question.
EIT
Quote (PEinc): A tiedback wall would not be the first solution that I would investigate.
No, not a cantilevered wall. I would consider flatter sloping, maybe soil nailing, or maybe terracing several lower walls with some setback between each level.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
