Hello all,
I have a bit of a problem. I have a spare girth gear that (might) belongs to a ball mill, and I need to check it with the pinion, and perform contact test, backlash, radial and axial runout (2 sections), et cetera). There is a distinct possibility the pinion does not correspond to the gear for whatever reason (cough!, cheap, cough!).
As we do not have a spare mill lying around, I am thinking of building a structure with supports for gear and pinion. And with an old motor and belts make them turn. Is there a more efficient way to do this?
Unfortunately we do not know if the gear belongs to the pinion, or even if the sections of the gear belong to each other, if it has cracks, how worn is it (we can see visually it is worn, but not as much as the one currently working), we do not know brand... In short, we do not know what we do not know... Helps would be highly appreciate it
regards,
JM
regards,
JM
