Zero Backlash Universal Joints
brdaaw
6
I'm looking to incorporate a small (12-15mm OD) u-joint with little or no backlash. It would need to operate at >=20 degrees around 10RPM. In my industry, we manufacture almost everything unless it's made by an approved vendor, which is an exhausting process. I've found the attached u-joint, but can't figure out how it's made or how to design something similar. Any thoughts on alternative designs or how these are made?
You have to consider the rest of the hardware in the drive line, not just the joints. Splines and other couplings will add backlash.
Update: the outer ring is definitely made of two plates welded together.
@Swall - I'm actually more concerned with translation in the u-joint than rotational backlash.
The scale might be unusual, but disk couplings are clearance-free, torsionally and radially stiff. I'm not sure, but your "backlash" might be radial stiffness and zero clearance?
For low torque I wonder how a piece of rubber hose would work.
At +/- 20 degrees angularity, you might consider a flexible shaft
There is a relatively large axial load and the position of the shaft must be precise. I fear that any flexure joint or flexible shaft would allow for too much translation of the shaft. Thoughts?
Applying a large axial load to one half of a u-joint with significant angulation, as in this case, develops a relatively large radial load on the opposite half's ear, and a significant thrust load on the related leg of the cross. Most commercial u-joints are designed for relatively small radial loads, and will exhibit significant deflection and wear when so misapplied.
I.e., if I am understanding your loading case correctly, you will be better off developing a custom solution from scratch than copying someone else's design that you do not understand.
Mike Halloran
Pembroke Pines, FL, USA
Along the lines of rubber hose - a metal bellows (e.g. Servometer) can pass a heck of a lot of torque. The advantages of such devices are they don't have the fluctuating rotation (2x/rev) that a cardan joint gives.
oh, and my other point - true zero backlash, no bearings/joints to wear and start to develop increasing backlash over time.
life span is not an issue, as it's an expensive disposable part. The duty cycle will be extremely low - something like 300 revolutions.
