Youngs modulus of 304SST ?????
  • Thread starter Thread starter ksarita20
  • Start date Start date
K
ksarita20
Guest
hi ,
I am doing a structural analysis on a rod made of 304SST. Can any one please tell me the youngs modulus and densityof that material.
what does SST stand for. what is the difference between SS420 and 304SST.
I will be very happy if anyone can help me out.
Thanks in advance.
Sarita
In general Stainless Steel is 27.5 MPSI or 190 GPa (Young/Elasticity) and .28 lb/in3 or 7700 kg/m3.
The difference between alloys would usually be negligible.
Hi Scottm,
Thanks.
So can we suggest to any on of them , when we consider the mechanical properties??
And can u suggest a good source where i can get details about mechanical properties of metals.
THnaks
Sarita
Try matweb or azom... these are 2 very good website's
TinaG
MATERIAL
SS_304&n bsp;&n bsp;
This file may be edited using available editor.
Just type on the necessary lines appropriate values
after the "=" sign. Comments are not permitted on
lines containing material properties names.
YOUNG_MODULUS&nb sp;&nb sp;
= 2.800000E+07
POISSON_RATIO&nb sp;&nb sp;
SHEAR_MODULUS&nb sp;&nb sp;
MASS_DENSITY&nbs p;&nbs p;
= 2.900000E-01
THERMAL_EXPANSION_COEFFICIENT = 9.600000E-06
THERM_EXPANSION_REF_TEMPERATURE = 3.200000E+01
STRUCTURAL_DAMPING_COEFFICIENT =
STRESS_LIMIT_FOR_TENSION&nbs p; = 6.000000E+04
STRESS_LIMIT_FOR_COMPRESSION = 6.000000E+04
STRESS_LIMIT_FOR_SHEAR =
THERMAL_CONDUCTIVITY&n bsp;
=&nbsp ; 9.400000E+00
EMISSIVITY
SPECIFIC_HEAT&nb sp;&nb sp;
= 1.200000E-01
HARDNESS&n bsp;&n bsp;
CONDITION& nbsp;& nbsp;
= SST_304
INITIAL_BEND_Y_FACTOR& nbsp;
=&nbs p; 5.000000E-01
BEND_TABLE
= ss_304
PRO_UNIT_MASS&nb sp;&nb sp;
= unit_pound
PRO_UNIT_LENGTH& nbsp;
= unit_inch
MATERIAL
SS_440&n bsp;&n bsp;
= 2.900000E+07
= 2.800000E-01
THERMAL_EXPANSION_COEFFICIENT = 6.200000E-06
THERM_EXPANSION_REF_TEMPERATURE = 6.800000E+01
STRESS_LIMIT_FOR_TENSION&nbs p; = 1.000000E+05
STRESS_LIMIT_FOR_COMPRESSION = 1.000000E+05
=&nbsp ; 1.400000E+01
EMISSIVITY
= 1.100000E-01
= SST_440
BEND_TABLE
= unit_pound
= unit_inch
these are from the files section then the materials file
anyone got the specs on 316ss?
