I'm constructing an S&N Fatigue diagram for an Al 6063 T1 part. I performed a FEA analysis and found the largest VonMises stress 17ksi located where I expected it to be. I'm expecting the bending stress to fluctuate in tension (+), so a book I have instructs to designate (Sigma Alternating) as 1/2 the amplitude of the stress (8.5ksi), which will be what I use to intersect the S&N plot correct?
The S&N diagram starts at N=10^3 cycl, Sf = .9 UTS = 19.8ksi.
According to the yield strength of AL at 13 ksi this part has has plastically deformed at 10^3. It is hard to believe that this part will endure 1000 cycles at 19.8 ksi before "failing"
Does this sound right? By the way I thought the part "failed" as soon as you pass elastic deformation.
Comments and suggestions appreciated
