greenimi,
The new stabilization default for RMB datum features will have some impact, but I'm not sure how much. I suppose that this depends on how often candidate datums on a rocking primary datum feature actually come into play. How often do you see a part rocked to an optimal orientation on a surface plate during inspection? I haven't seen that very much. When a part is CMM inspected, the software rarely/never tries different candidate primary datum planes.
Regarding total runout on a cone, I'm wondering what your objection is and why you feel it should be disallowed. Personally, I don't have a problem with it. Regarding the addition of the term "cylindricity", I don't think that this changes anything about the definition itself. It's a description, intended to aid understanding. When applied to a cylindrical feature, total runout limits the worst-case cylindricity error. It's an indirect consequence of conforming to the total runout requirement.
pylfrm,
Some of the additional pages represent new content, but a lot of it is from additional model-based versions of the figures. I also noticed that some of the figures are larger, taking up an entire page.
3DDave,
Total runout doesn't limit variation parallel or perpendicular to an axis. It's often portrayed that way, as this provides a useful description for cylindrical and planar surfaces. Point the indicator perpendicular to the datum axis for cylinders, and parallel to the axis for planes. But the requirement is really that the indicator needs to point normal to the basic surface. So this doesn't rule out cones and curved surfaces of revolution, but it does require that they be defined with basic dimensions and not with directly toleranced dimensions. This has been a sticking point - what to do when the angle of a cone is defined using a directly toleranced angle?
Dynamic profile cannot be covered by composite profile tolerancing - it's something different. Composite profile allows the tolerance zones in the lower segment to translate relative to the DRF. Dynamic profile allows the tolerance zones to "progress" (offset). I agree with pylfrm that this is a generalization of total runout.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
