Hi folks !
I have received a CD with a large number of drawings on it - and each contain many xrefs - the xrefs are in a seperate dir on the disk > Upon opening the drawing the xrefs are not found as it's looking for them elsewhere .....
now it's simple enough to re-path each xref in every drawing - but very time consuming ! Is there any way of doing a global re-path ?!?!
ie "look here instead,for ALL your xrefs" lol.
Ideally i need to copy the full set into the project dir on our network.
AHAAAA - jst tried sthing> the drawing was looking for the xrefs withn the same dir as each dwg - but theyd been separated on the disk - I just copied thm to my network and put dwgs AND xrefs in the same directory - and it has loaded them all ! (though the dir name is now differnt to original name in path)
would this still work ....if the xref path had been looking in a sep dir to the actual dwg originally? will a drawing ALWAYS look for xrefs within it's 'own' directory even if the path says otherwise ?
any help/comments appreciated - cheers
