I have a question. I have a successful photodetector circuit with 8-bit resolution from an on mcu adc. works well from a dark room to room well lit. The detection comes from a simple 1n4148 glass encased diode a couple of op amps to give a dc offset for low readings and approximatley 100 times gain. QUESTION: What would have to occur to make this an Xray detector. The radiation is in the medical diagnostic range 50kVp - 120kVp. The circuit will do nothing in the radiation beam and my thoughts would be it should register full on the same circuit as the photodetector; higher frequency beam higher energy and therefore a higher reading on the same circuit.
Any suggestion greatly appreciated; XRAY
