Redskinsdb21
Mining
- May 4, 2009
- 45
If a Transformer is listed at 12470Y/7200 Primary and 480Y/270 secondary (Shown AS 12470Y/7200V for primary and 480Y/270 secondary) does this mean the primary must be wired in a Y configuration if to be used at 12470 V and if you use a neutral on the primary then it would be 7200 V? With the Y being beside 12470 does this mean it cannot be used to replace an existing Delta-Wye wired transformer?
I am trying to replace an existing 12,470 pri/480/270 sec Xfmr that I am told is in a delta/Wye configuration but have not been able to go out and check yet.
