I am not running Creo but you create your x-sections in the 3d part not in the drawings. In the 3d model, go to view manager, xsec, new and pick planer or offset (sketch cut with jogs).
You can create x-sections in drawing mode from the view properties dialog box. Select the Sections section of the view properties dialog and Create New from the drop down list. The same dialog should come up that is seen in part mode. Offset section definition will put you in part mode while defining the section and switch back to drawing mode to finish the view definition.
