ThePunisher
- Nov 7, 2009
- 384
Hi all. I am doing PER-UNIT calculation using P.U. (R + jX) as per ANSI standards. In calculating the X/R ratio at the fault point, I used equivalent (P.U. jX)/ (P.U. R).
However, I read a book that states that calculating X/R ratio using complex form (P.U. jX)/ (P.U. R) is not conservative and not recommended for ANSI calculations. It stated that an Rseparate/Xseparate should be used.
I am bit confused as to what and how to calculate separate R and separate X. Are they different from (P.U. jX)/ (P.U. R)?
regards
regards
