So we had to install two transformers to stepup/stepdown the voltage due to long distance from solar field to interconnection point.
They are 480V Y, 12KV delta & 12KV delta, 480V Y transformers while interconnection is at 480V.
The question is what happens when there is a fault on the delta side. Will the elevated voltage be seen on low voltage (480V) side or because the voltage is dictated by utility side there won't be elevated voltage on either of 480V sides during the ground fault?
