The twists and turns of this thread. From designation of reinforcing, which is apparently different in every country, to where it is best placed in a slab on ground, and to quality in different places.
We use a lot of reinforcement mesh in Australia, both in slabs on ground and in suspended slabs. Probably because it is used so much in suspended slabs, our workers seem to give it as much respect as bars in terms of placing accuracy. Our standard bars are now deformed, 500 MPa, and the standard sizes are 5, 6, 6.75, 7.6, 8.6, 9.5, 10.7, and 11.9. Square meshes are usually at 200 centres each way. Rectangular meshes with the main bars at 100 centres are readily available for one way slabs, and special orders are often done for large projects.
