Aknil
- Jan 8, 2010
- 11
Hey all
(i would post this in http:~~qid=210934#post but it's closed)
I am simulating a micro package, Frame soldered to glass.
cooling down time is below 4ms.
my IC is a hot solder (not liquid tho) at 300°C cooling down to 25°C. no other forces, just a uniform temperature (set prior to IC) of 25 degrees.
when i run the thermal transient solution (Large displc. 100 sub steps, time the end of load stre 0.05) i get funny results, in the first 3-4 steps my frame is -5°C which maked no sence.
I tried:
- increasing load steps
- doing 2 load steps, but IC is lost when running the loadstep 2
- small displacement
nothing worked, pleae advice.
I tried:
