Quick question - I'm running SW 2008 Premium in an engineering consulting environment. I have a customer that has given me a .WRL file that I need to do some FEA on. Can I convert this to something that I can use???
It's a VRML file. You can import VRML files into SW as solid bodies, but it will be a faceted solid. It will look like a cross between STL and IGES. In order to do an analysis you might have to clean up some round surfaces.
