Wrapping. Trouble creating the continuous surface.
mmakm
21
I'm attempting to wrap a sketch around an object but my surface needs to be continuous. I've attempted extruding a sketch with lines and curves, but this doesn't give me a that contiuous. I ended up fitting a spline and extruding it but it would seem to me there is an easier way. Is there a way to convert sketch entities(lines & curves) into a spline?
Yes, use the Fit Spline function in the Splines toolbar.
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Ohh ... Is that what you meant by "I ended up fitting a spline"?
Also, do you mean you want the wrapped sketch to be continuous?
[cheers]
