am having a very frustrating issue. I have been trying to get this code to work for over two weeks and I have had only partial success.
I have been trying to utilize NX's remoting features so I can get Excel to talk to NX and vice versa.
I am writing it in Visual Studio Professional Edition 2012 and I plan on compiling the code as a Console Application,
I have been able to successfully link Excel to NX remotely which is a big first step for me.
However now, I am trying to use the Workbook_sheetselectionchange event as a way to activate certain events based on user input.
The problem is that the sheet selection event will not fire off!
The subroutine ProcessNXData fires off just as it should and collects the necassary data from NX and populates the Excel spreadsheet. After that, I do some clicking and nothing...
I have no idea what is wrong. Any help would be greatly appreciated. Thank you!
(64 bit is Target machine, Microsoft Office 2010)
Code:
Option Strict Off
Option Infer Off
Imports System.IO
Imports System.Runtime.Remoting
Imports System.Runtime.Remoting.Channels
Imports System.Text
Imports System.Diagnostics
Imports System.Collections
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpen.Utilities
Imports NXOpen.UF
' add project COM reference: Microsoft Excel xx.y Object Library
Imports Microsoft.Office.Interop ' import Excel Interop Namespace
Imports System.Runtime.InteropServices.Marshal
Imports Microsoft.Office.Interop.Excel
Imports System.Windows.Forms
Module remoting_client_test
Public theSession As Session = DirectCast(Activator.GetObject(GetType(Session), "[URL unfurl="true"]http://localhost:4567/NXOpenSession"),[/URL] Session)
Public ufs As UFSession = DirectCast(Activator.GetObject(GetType(UFSession), "[URL unfurl="true"]http://localhost:4567/UFSession"),[/URL] UFSession)
Sub Main()
Dim myForm As New Form1
Dim Target As Range
'need to initialize value of excel object variables
myForm.OpenWorkBook("C:\Users\User\Documents\TestFile.xlsm")
myForm.ProcessNXData()
End Sub
Public Sub DoLog(s As [String])
Session.GetSession().LogFile.WriteLine(s)
Console.WriteLine(s)
End Sub
Sub Echo(ByVal output As String)
theSession.ListingWindow.Open()
theSession.ListingWindow.WriteLine(output)
theSession.LogFile.WriteLine(output)
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Public Class Form1
Private WithEvents excel As Excel.Application
Private WithEvents workbook As Excel.Workbook
Private WithEvents worksheet As Excel.Worksheet
'some variables required for excel
Public row As Long = 2
Public Sub OpenWorkBook(path As String)
If excel Is Nothing Then
excel = New Excel.Application
excel.Visible = True ' user is responsible for closing Excel
excel.UserControl = True
End If
If workbook IsNot Nothing Then
FreeCOM(workbook)
End If
Dim workbooks As Excel.Workbooks = excel.Workbooks
workbook = workbooks.Open(path)
FreeCOM(workbooks)
If worksheet IsNot Nothing Then
FreeCOM(worksheet)
End If
Dim Worksheets As Excel.Sheets = workbook.Worksheets
worksheet = CType(Worksheets.Item(1), Microsoft.Office.Interop.Excel.Worksheet) ' 1 based indexing
End Sub
Public Shared Sub FreeCOM(ByVal COMObj As Object, Optional ByVal GCCollect As Boolean = False)
Try
If COMObj IsNot Nothing Then
System.Runtime.InteropServices.Marshal.FinalReleaseComObject(COMObj)
End If
Finally
COMObj = Nothing
If GCCollect Then
GC.Collect()
GC.WaitForPendingFinalizers()
End If
End Try
End Sub
Public Sub ProcessNXData()
Dim displayPart As Part = theSession.Parts.Display
Dim workPart As Part = theSession.Parts.Work
Dim markId1 As NXOpen.Session.UndoMarkId = theSession.SetUndoMark( _
NXOpen.Session.MarkVisibility.Visible, "Reorder Components")
Dim theOrders As Assemblies.ComponentOrder() = Nothing
displayPart.ComponentAssembly.GetComponentOrders(theOrders)
Echo(displayPart.Leaf & " has " & theOrders.Length & " ComponentOrder objects")
For Each anOrder As Assemblies.ComponentOrder In theOrders
anOrder.Activate()
theSession.UpdateManager.DoUpdate(markId1)
Echo(anOrder.Name & ":")
WalkAssembyTree(displayPart.ComponentAssembly.RootComponent, anOrder, "")
ufs.Ui.DisplayMessage(anOrder.Name, 1)
theSession.UndoToMark(markId1, "")
Next
theSession.DeleteUndoMarksUpToMark(markId1, "", False)
End Sub
Sub WalkAssembyTree(ByVal theComponent As NXOpen.Assemblies.Component,
ByVal theOrder As NXOpen.Assemblies.ComponentOrder,
ByVal indent As String)
Dim kids As Assemblies.Component() = theComponent.GetChildren()
If kids.Length = 0 Then Return ' Not an assembly or sub-assembly
indent = indent + " "
' This does not always work - see PR 7421390
' Testing in the Toycar assembly only Chronological returns any Children
kids = theOrder.AskChildrenOrder(theComponent)
For ii As Integer = 0 To kids.Length - 1
Echo(indent & kids(ii).DisplayName)
If kids(ii).HasUserAttribute("DB_PART_NAME", NXObject.AttributeType.String, -1) = True Then
excel.Cells(row, 2) = (indent & kids(ii).GetStringAttribute("DB_PART_NAME"))
Else
'do nothing
End If
excel.Cells(row, 3).Value = (kids(ii).ToString())
' Process parts here
Dim thisPart As Part = kids(ii).Prototype()
If theOrder.OrderType = Order.Type.ChronologicalComponent Then
processThisPart(thisPart, indent)
row = row + 1
Else
Continue For
End If
WalkAssembyTree(kids(ii), theOrder, indent)
Next
End Sub
Public Sub processThisPart(ByVal p As Part, ByVal ind As String)
Dim theBodies() As Body = p.Bodies.ToArray()
Echo(ind & "Bodies in part: " & theBodies.ToString())
For Each thisBody As Body In theBodies
'Echo(ind & thisBody.ToString())
'======================== Other desired processing here
excel.Cells(row, 3).Value = (ind & thisBody.ToString())
Next
End Sub
End Sub
Public Function GetUnloadOption(ByVal arg As String) As Integer
End Function
Private Sub worksheet_SelectionChange(Target As Excel.Range) Handles worksheet.SelectionChange
Dim theSession As Session = DirectCast(Activator.GetObject(GetType(Session), "[URL unfurl="true"]http://localhost:4567/NXOpenSession"),[/URL] Session)
Dim ufs As UFSession = DirectCast(Activator.GetObject(GetType(UFSession), "[URL unfurl="true"]http://localhost:4567/UFSession"),[/URL] UFSession)
Dim dp As Part = theSession.Parts.Display
Const undoMarkName As String = "NXJ journal"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
'Remoting Worksheet: Cycles through component objects by name, and then when finding it, highlights it.
'Dim theCompName As String
Dim theCompTag As NXOpen.Tag = NXOpen.Tag.Null
Dim RemoteValue As Range
Try
Debug.Print("worksheet selection change" & Target.Address) ' for testing only, will do nothing in an executable
RemoteValue = Target.Value ' you can test if target is a valid value here or in remotevalue later
Left(RemoteValue, Len(RemoteValue))
ufs.Obj.CycleByNameAndType(dp.Tag, RemoteValue, _
UFConstants.UF_component_type, True, theCompTag)
If theCompTag.Equals(NXOpen.Tag.Null) Then
Echo("No component found with that name. Exiting...")
Return
End If
Catch e As NXException
Echo("NX Exception is: {0} " + e.Message)
Catch e As Exception
Echo("Exception is: {0} " & e.Message)
Echo("DONE!" & vbLf)
Finally
ReleaseComObject(Target)
End Try
End Sub
Private Sub Form1_FormClosed(sender As Object, e As FormClosedEventArgs) Handles Me.FormClosed
FreeCOM(worksheet)
End If
FreeCOM(worksheet)
End If
If excel IsNot Nothing Then
FreeCOM(excel, True)
End If
End Sub
End Class
