Workpiece display in drawings
  • Thread starter Thread starter penjas14
  • Start date Start date
P
penjas14
Guest
For some reason my workpiece in drawing mode is "transparent". I can see through it and whatever is under it.None of the other parts in my assembly are this way.I've tried changing the HLR display for theworkpiece but it doesn't change anything. It wasn't like this before so I'm not sure what happened. I am using WF4 M050.
In view properties change setting:
no hidden, tangent: none
could u post image how it looks like..that may help
The part is set to Workpiece in my Manufacturing file. The 2 parts you see are Station 1 and 2. I have the drawing poperties set to No Hidden and Tangent Edges - None. But you can see through the workpiece.
Check if your workpiece model are solid or surface.
It is a solid that I created using an extrude.
Ok. Then I have no clue.
This is the way how proe handles workpieces, if it would make it solid (not transparent) you wouldn't be able to see what you're milling.
What i use as a workaround, is loading the same part as the workpiece as a part to be milled. then i use a Simplified rep on the drawing to show only this part and not the workpiece. When i'm creatingsequences this part is suppressed or hidden. (or added after i'm finished)
