Working with Parameters in BOM
  • Thread starter Thread starter dias_ryan
  • Start date Start date
D
dias_ryan
Guest
Hey guys. I am having a TONNE of trouble trying to create an assembly drawing that updates its own Cost field in the BOM.
So. I have right now:
Ibeam.ipt - parameter Length - 15 in ** model variable
- parameter UnitCost - 4.0 ul
- parameter ValueEa - (Length * UnitCost) 60.0
I move to the assembly drawing and want to create a Total Cost parameter
Assembly.iam
- parameter ValueEa - 60.0 **stolen from the ipt
- parameter QTY - 3 ** 3 pieces in the assembly
- parameter Total_Value - QTY * ValueEa
This final parameter is giving me grief! ValueEa will not translate into the assembly file. Is there a linking procedure i have to do? I clicked Export in the Parameter window. The QTY parameter is not working for me either. Am i not allowed to us it in a calculation?
Reply from Autodesk...
Located this reply from kgrunawalt at Autodesk development.
Good Luck!
3DCADTips Help Desk :cool:
Reply From: kgrunawalt
Date: Jun/06/06 - 09:58 (CDT) NEW!
Re: BOM Parameters
I'll speak to the QTY as seen in the BOM. This is not a parameter. It is a total calculated per row in the bom view. A BOM with 5 different parts will have 5 different QTY values.
I think you want an excel like equation that references values relative to a row. Then you could do ITEM QTY * cost and ITEM QTY would have a row context. This is not supported in the current BOM or parts list. You are not the first to request the ability to calculate total costs. I will make sure this need is logged.
Katrin Grunawalt (Autodesk Dev.)
stolen from the ipt
Hey dias_ryan,
please let me know to export parameter from ipt to iam so it can be shown on the BOM on the dwg.
Thanks!
Assembly.iam
