HofOblivion
I have a plan check correction about using the wood shear walls and pre-approved panels such as strong walls on the same line of resistance.
The plan checker believes that "the combinations should not be used as the stiffness between them is unknown and questionable."
I believe the question to be far-fetched although I believe the question to be somewhat valid.
Am I wrong here?
Am I wrong here?
