ron9876
- Nov 15, 2005
- 669
I have a condition where a wood framed floor is spanning 14'-8" between masonry walls. I am considering using No. 2 Southern Pine 2"x12" floor joists at 16" c/c. The ceiling will be drywall and the floor will have 3/4" T&G plywood glued and screwed. Have an area with no walls below or above to help with damping.
Minimal mechanical equipment and hardwood flooring. Is there a procedure for checking vibration. Thanks for any help.
