ajk1
- Apr 22, 2011
- 1,791
In CSA Standard O86-01, Table 5.4.4, the "System Factor" Kh is given for "compression parallel to the grain" as 1.10 for Case 1, and 1.00 for Case 2 built-up beams. There is no listing for built-up columns. I am checkimg a built-up wind-column in the exterior wall of a cottage. It takes s small axial load due to roof dead load and snow, and a wind load which has a much greater effect than the axial load.
Questions:
a) Would I be correct to use Kh=1.00 for the resisting momnet calculation, and 1.10 for the compression strength of the column?
b) Why have they listed "built-up beams" but not listed "built-up columns" in the table?
c) Why have they listed built-up beams for CAse 2, but not for case 1?
d) Do other Standards have a similar table, and if so, what have they listed for Kh?
e) Has anyone used this table for VSL wood (i.e wood studs made up of vertical laminations), or is it not applicable?
I can attach a photographed copy of the table if that would help (I don't have a scanner at home).
Questions:
