I currently have a wood plate attached to the top of a concrete wall supportin wood roof trusses. The trusses were built with a heel height that was 4.5" too short. Our solution is raise the trusses and bolt (3) more 2x plates to the existing one. When you analyze this connection using NDS can you consider your main member 4.5" thick and your side member 1.5" thick? Do the yield limit equations still hold for multiple plies that are unconnected? How should the connection be designed? I need to transfer about 400plf of shear load out of the roof diaphragm. Any help would be great.
