palk7 EIT
- May 12, 2020
- 159
In order to have infill studs beneath a wide opening 20' could wood beams on flat (multiple) be used as a girt as attached in the pic, since clip angles are used at every stud to this girt could the span for analysis of this girt be reduced to the spacing of studs or the span has to be considered 20 feet as that of between the col's. Max. trying to avoid using a steel girt here. This 3' height infills are creating hinge as it is being added to exist. structure. Any advice?
Thank you!
Thank you!
