adventurer
I wonder if there are any codes/standards out there to address industrial equipment, specifically the small-signal control circuitry and wiring they often utilize.
For instance, I know that it is good practice, but is there a code or standard out there that actually says to keep AC and DC signal wires separate? And when wiring small signals such as to PLCs, is there a code/standard that specifies what wire sizes to use? The NEC doesn't really show anything above 18 gauge, which handles 18 Amps. What about color? Does it matter? Or issues such as strapping the wire or harness properly when running to a hinged panel, to avoid stressing the cables.
There are a ton of little issues that arise for which I've never seen a comprehensive guide/standard. What to do?
