I'm not sure if this is the correct forum for my question, but thought I'd give it a shot nonetheless.
Im wondering if there is an existing technology to accomplish the following:
I need to arrange (2) points (for example, the centers of 2 quarters) such that an imaginary straight line connecting the (2) points is parallel to a 6" length straight rod of some kind. The (2) points would never be more than 5' from the rod in 3-dimensions (i.e. the rod will be situated at a higher altitude than the objects). Ideally, the (2) points would be moved around until the line between them is parallel to the rod, at which point a light, or some other kind of indicator, would flash to indicate proper alignment. I would need this to work wirelessly.
Any help/insight is greatly appreciated. Thanks.
