WindowsXP - need more memory
jsmc
Military
Dec 16, 2003
8
We use UGV18 and ProE2001 on Win2K platforms.
A UG session will consume 1.9Gig of RAM, before running out of memory and crashing: ProE 2.2Gig (this according to information read from the Windows task manager).
Incidentally, multiple sessions of UG and/or ProE will each run to the above limits simultaneously.
Our impression has always been that the platform, and not the applications it runs, limits the amount of available RAM.
We're soon to change to a WindowsXP platform, and preliminary testing shows no improvement. We expected to get 3.5Gig .
Has anyone else encountered this ?
We have encountered this situation with UG NX on WindowsXP platform with 2GB RAM. Dosen't matter how much is the total of available memory, our system run out of memory at 1.91 GB. Can you tell me how much of RAM you use to your system?
Because we intend to increase at 3 or 4 GB of RAM and if it is a problem of the platform I don't no if is usefull to increase the RAM.
Thank's
"Can you tell me how much of RAM you use to your system?" ... 4GB
We have one SUNBLADE to handle LARGE assemblies with 4gig of ram, and it works good but is lite more expansivier than a PC
Hi jsmc!
You must login like Admin and write in the file C:/boot.ini the following line:
/3GB
This increase the allocated memory for one process up to 3GB
We have tryed and it works!
Have a nice day!
