Windows 7 and NX
larrylcoyle
Automotive
Is anyone running NX4 or any version of NX on Windows 7? If so, what did you have to do to get it to install correctly? When installing my license server for NX4, it doesn't want to start the server.
Thanks,
Larry
Larry Coyle
Managing Partner
Cylinder Head Engineering, LLC
CNC Porting
De Soto, KS 66018
NX7 will be certified for Windows 7.
Older versions of NX should work.
There has been more discussion on this on the internal BBS.
Ben Loosli
Thanks Ben,
I know it should work but with my luck, I can't even get it to install properly yet...
Larry Coyle
Managing Partner
CNC Porting
De Soto, KS 66018
Versions NX4-5-6 32-bit work well with SO 64-bit?
Thanks to all.
Ciao.
Just wondering of the Windows 7 users, without adding memory, do you find NX6 runs any different than in XP? Any real reason to change other than the increased memory upgrades?
Bill
haven't notice much different, when switching from component files to main assembly files in LARGE files the render time is much less (likely a memory benefit). It does 'think' through some surfacing stuff quicker, but not overly significant. 64bit version of nx may be different however.
Be aware that only XP is certified to run NX4 at this point in time, so no support if you go this route and end up having any issues.
Tim Flater
Senior Designer
Enkei America, Inc.
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
Man2007
Thanks very much for the link. It definitely works. With the exception of postbuilder though. I really appreciate all of the advice.
Larry
Larry Coyle
Managing Partner
CNC Porting
De Soto, KS 66018
