Wind uplift for a Polyethylene Line Sludge Lagoon
renko
IE
I'm working on a sludge lagoon design for a Water Treatment Facility in Ireland.
To counteract wind uplift of the liner sheet , the proposal is to use concrete/soil filled pipes as ballast.
Can anyone advise on a standard detail for this - pipe sizes, lengths, centres.
If anyone has used this method before I'd appreciate some advice.
Thanks.
Could you use vents instead... They may be more cost effective. I am working on a lagoon project as well. Did you end up using concrete/soil filled pipes as ballast in your design? Standard details for vents can be found at the below link.
Yes I specified the concrete filled pipes held in place with HDPE welded straps.
Thanks for the vent detail - does this present leaking problems?
