phamENG
- Feb 6, 2015
- 7,715
A search of the forum and the internet in general failed to provide a very good answer, so hopefully somebody here has a good reference. I'm designing a 5 story, u-shaped building. Overall dimensions are about 180ftx180ft with a 60' "thickness" - pretty standard apartment building. Standard, that is, so long as you're not looking at ASCE 7-10. It sadly falls outside of the realm of regularly shaped buildings and into the need for "approved literature" or "wind tunnel testing." Well I can tell you we can't afford to rent the local wind tunnel, so I'm hoping for some good literature to apply. My gut tells me that the orthogonal wind loads should be roughly those calculated for a rectangular building (a slight increase when considering the sides of the U, and perhaps a bit of eccentricity from the unbalanced internal pressures in the courtyard), but a quartering wind has me concerned. A side note, this is on the east coast and wind will more than likely control most of the lateral design (with the possible exception of an amplified collector load on the first floor here or there).
I found this presentation from NCSEA, but the resolution is bad and I can't find it replicated anywhere with the actual explanations that were probably given by the presenter.
Thanks for any help you can provide.
