wikidcool
- Jun 20, 2007
- 50
I've been asked to analyze a large greenhouse. It's approximately 360 ft long x 240 ft wide. The design is basically 12, 30 ft wide x 240 ft long gable roof frames stacked side by side (See attached elevation). ASCE 7-10 gives roof wind pressures for gable roofs, but doesn't address this particular configuration. The governing ASCE7 loads would apply the same positive pressure to every windward roof face, and the same negative pressure to every leeward face. I suspect the roof wind loads normal to the ridge behave differently on a building like this. I'm wondering if they get the same effect a gable roof does with wind parallel to the ridge, where the force decreases as you move further away from the windward edge. If so, applying the code loads to every surface might be excessively conservative?
I'm having trouble locating any up to date guidance about it. Does anyone have experience with this subject they can share?
Thanks in advance.
Thanks in advance.
