jonnywalker
Seems like a simple question but the loads that I am coming up with are huge! The structure is a simple cantilevered column that supports cables with fabric spanning between the cables.
Attached is a plan view of what is happening. On one side of the 60' span the columns are 18' and the other the column is 12'. The client doesn't want the cable so sag more than a couple of inches...
Ive gone into the ASCE 7 code and come up with a 13psf load @ the top half and 3.5psf for the bottom half of an open structure with a pitched roof. This load is being applied to a tributary area of 150 sq ft. Ive gone back and read my structrual analysis books but it seems to only address uniform loading...Ive also gone back through some old forums for some help....
My question is: is this the correct way to come up wind loading on this type of structure? I imagine there will be flutter, and neither method is valid for a structure with flutter.
If not this code would i use ASCE55 for Tensile Membranes Structures or ASCE74 for Transmission Lines? Would it be considered a tensile membrane? Ive also looked at transmission lines and investigated SAG10... Thanks for your time! JW
