I guess we have to recognise that this is the student forum, and maybe he's been told "consider wind effects".
If so, windage is a distributed load, the suggestion above is something like 25 pounds/sq ft (and a sq ft is 1 ft length * x ft diameter). Now you can use that number or you can calculate it (or maybe there's a code reference you can use ?) or maybe your can say "assume windage loads negligible" ? (what year are you in ?)
But the key thing to determine your actuator point is the bending moment of the tower. Also the length of your actuator (how much it extends)
If we're talking practical aspects, there'd be two guy ropes to control the out-of-plane (and so small loads (like windage can be managed this way.
