I'm working with four above ground, low profile truck scales (bottom of the scales 7-18 are inches above grade). Wind effects cause fluctuations on the readings up to 600 lbs, both positive and negative, with or without traffic on the scale. Fluctuations occur regardless of wind direction. The scale company already provided some dampening of the scales to limit the fluctuations. This helped, but did not solve the problem. A large wind wall was constructed at one scale but is questionable whether it helped.
Any other suggestions? Blocking wind from beneath the scales would be easiest to construct. But, how much of the fluctuations are due to wind OVER the scales? How to quantify this with any reasonable accuracy?
I suspect this problem is not unique and has been resolved successfully somewhere...
