Aerodynamics is not my field, so my apologies if this is an obvious question.
I've got a (relatively) tricky build with an option to place fans about 1cm apart (blowing in opposite directions (i.e. away from each other))
I'm wondering if or how badly they will compromise each others performance at that proximity.
Would it be similar to placing a fan a centimeter away from a solid surface or are there other factors to be taken into consideration?
How much clearance is needed behind a fan for it's performance to remain uncompromised?
If you guys could shed some light on the above for me it'd be very appreciated.
