Will not be tied to the master surface assembly
zeroburn315
Aerospace
Sep 26, 2013
13
I am trying to tie 2 shell elements but It give me this error:
Slave node 1680 instance del3-1 will not be tied to the master surface assembly_m_surf-1. The distance from the master surface is greater than the position tolerance value.
I have tried everything but still its not working. I have used find pairs, did it manually, increased the tolerance even to the unreasonable values but still no solution. And because of this My work is stuck. I have to present the analysis to our customer by friday so please if anybody can quickly give any advice or help that will be really appreciated.
Note: I have also tried to change the master and slave position, played around with meshing as per google, I even created the parts again from the scratch. Here are the images if you are wondering:
Top PLate (Shell)
Base Plate (Shell)
I want to tie them together Top plate on the shell plate. (The size and dimensions of both the parts are same) I am using shell because of composite material.
You can use the POSITION TOLERANCE under Tie Contact. Just give a value more than the gap between the Master and Slave under POSITION TOLERANCE in the TIE contact pair. It will certainly work.
Hope this will help you.
Prasad
